Parent Workflow
How can we pass parameters from child to parent workflow?
We can pass values generated in the child workflow to the parent workflow using the Copy rows to Result step or mapping child fields to parent fields.
In the Workflow Executor Result Rows tab, enter field names exactly as in the child workflow that you wish to pass from child to parent workflow in the result rows. You can leave it blank if you want to see all the fields in the child workflow as part of the result rows, however for that you need to add the Copy Rows to Result step at the end in the child workflow.
