Date filters in a dashboard report
To set date filters in a dashboard report select the correct options.
  • Select a duration either at dashboard level or report level
  • In case of Structured query in Template Wizard configure the Date Column Name parameter
  • In case of flat query in the JSON file specify - startDateParamNames" , endDateParamNames: , and refer to the param prepended with a colon in the query
  • In case of Structured query in the JSON file specify - startDateParamNames" , endDateParamNames: , and refer to the param prepended with a colon in the query
  • In case of flat query in Template Wizard specify the Date Column Name parameter
  • In case of a structured query in Template Wizard specify the Start Date and End Date parameters.
  • Dashboard reports always contain entire data set
0 voters
