To set workflow Id parameter filters in a dashboard report select the correct options.
- Select workflows to filter by at dashboard level or report level
- In case of Template Wizard (i.e. Structured Query) provide the Workflow Id Column Name
- In case of flat query in JSON specify - workflowIdParamNames" and refer to the param prepended with a colon in the query
- In case of flat query specify Workflow Id Column Name
- In case of Structured query in JSON specify - workflowIdParamNames" and refer to the param prepended with a colon in the query
- Dashboard reports always contain entire data set
0
voters
