Hello,
I have an excel input as below
And I want the output as below
any suggestions on getting this output will be helpful
below is the input file attached
CustDetails.xlsx (8.0 KB)
Hello,
Hi @Deepak_Y,
Sorry we could not reply earlier. What version of AE are you using?
Hello @hemanshu.rukadikar,
Thank you for your response,
Currently, I’m using 7.1.1 and also, need to do the same on the 5.4 version.
Thanks for the info.
I am attaching a Process Studio project. This is a simple working of your requirement. Just import the project in Process Studio. One of our developers has built this for you.
CommunityDemo.zip (9.0 KB)
Thank you for the quick response,
JFYI, the workflow you have share is static, which I have also built by two different methods.
Is there any way to make it dynamic in case we are getting N number input data from clients end in a similar manner as in the input file.
I thought it will work with for loop in javascript but after few trails I failed to do so.
