How to change file name of existing file by using process studio
I downloaded a file from my email, and I want to rename it.
Hi Rohit,
If you want to rename the file without interacting with the File Explorer UI, use the File Management functionality, if available in your Studio version.
Provide:
  • Source Path: C:\Users\Username\Downloads\Invoice.pdf
  • Destination Path: C:\Users\Username\Downloads\Invoice_November.pdf
If your Studio version doesn’t show a dedicated rename action, use the File Management move step with the source and destination in the same folder, changing only the filename. Keep the extension, use full paths, and check that no file already has the destination name so you don’t overwrite something.
