How to compare SWIFT Transaction Reference with CBS SWIFT_MSG?
Hi Team,
I have two Excel files:
  • A file: Contains TranRefe
  • B file: Contains MSG, which is a long message.
For each TranRefe in the SWIFT file, I need to check whether it is contained anywhere in any CBS SWIFT_MSG.
Example:
  • A: ABC123
  • B SWIFT_MSG: :::20:ABC123|:::32A:...
  • Result: Matched
If the reference is not found in any CBS row, it should be Unmatched.
I need to separate the A file records into Matched and Unmatched outputs.
Can this be implemented using a Child Workflow with a loop through the CBS data? If yes, which AutomationEdge plugins and fields should be used, and how can the found result be returned to the parent workflow?
Thanks.
Yes excel that can be done use =ISNUMBER(SEARCH("word", A1)).
To find the exact character position where the word starts, and return TRUE or FALSE
