I’m not able to enable the status in the workflow and I can’t find a solution
@leonardosaint748gma You need to assign the Workflow to an agent in order to be able to activate the Workflow at the Portal. Once you do that you’ll be able to activate the workflow.
Go To Agent → Workflow Assignment
