I am facing some problem while working on process studio
Hello Sir/Madam,
I am not able to work on automation as process studio workflow and while completing foundation course I am having problem solving assignments in it because I don’t have process studio software so how can I get this software?
Hi Amit.
You should have access to the AE server where you can download any materials and software you need to move on.
If you have this access, go to the Process Studio tab on the left and in the upper right corner you can download the Process Studio.
Unpack and execute Process Studio in the bin directory and login with the same credentials as you logged in the AE server.
Maybe you have to assign yourself a license in the AE server under the same tab where you downloaded the software.
Documentation can be found in the resources tab.
If you do not have access to the AE server, you may request a free access on the AutomationEdge web page. Business email have 30min execution time per month. Free email accounts have I believe 60 days access.
You may also request access through the academy requests.
Hope this helps
Thank u so much sir
