Problem:
Request showing Failure Status on AutomationEdge Server.
Log Error:
java.io.IOException: Transport Connector could not be registered in JMX: java.io.IOException:Failed to bind to server socket: tcp://0.0.0.0:61616?maximumConnections=1000&wireFormat.maxFrameSize=104857600 due to: java.net.BindException: Address already in use: JVM_Bind
at org.apache.activemq.util.IOExceptionSupport.create(IOExceptionSupport.java:28)[activemq-client-5.15.8.jar:5.15.8]
Solution:
The issue occured basically, while ActiveMQ Service no longer in Running mode.
In the logs, the 61616 port was busy, as shown - Address already in use.
Steps to follow:
To resolve this, we have to change the port number in two files-
- activemq.xml
- ae.properties
Change port from 61616 to 61617 or any other.
