While installing AutomationEdge 4.0.0 giving error for starting ActiveMQ service.
Shital_Nair, could you please share more details regarding your issue.
This is the problem at ActiveMQ side. Check your computer name if it has any spaces or hyphen signs or underscores(_) in it. For example, computer name “COMP-007” does not work while starting ActiveMQ service.
Please do the following:
Uninstall ActiveMQ service.
Remove any spaces or hyphen signs (-) from the computer name. Restart machine if needed.
Install ActiveMQ service using “Command Prompt as Administrator”.
And try again.
Hopefully this will solve your problem.
Ok, I will try.
Thanks a lot.
Regards,
Shital.
I have tried above process, but still getting same error. Please help.
Regards,
Shital.
Hi Shital,
Edit the conf file from path “ActiveMQ/bin/win64/wrapper.conf” and set a path:
- Java Application :
wrapper.java.command=%JAVA_HOME%/bin/java.exe
Hi Komal,
Thank you very much. Now its started.
Regards,
Shital Nair
