Javascript Injection creates new fields
Have used many times JSI but now, with the following code, new duplicate fields are being created in the stream.
Fields “teclado” & “numerico” are declared before going into JSI but stream afterwards has also “teclado_1” & “numerico 1” with no data in it.
How can this be avoided, because later on in the process it reports index problems.
const a = document.getElementsByClassName(“boton_teclado_virtual”);
const n = document.getElementsByClassName(“boton_numpad_virtual”);
var teclado = ;
var numerico = ;
for (let j = 0; j < n.length; j++) {
numerico[j] = n[j].value;
for (let k = 0; k < a.length; k++) {
teclado[k] =a[k].value;
return “<<>>teclado::” + teclado +“<<>>;<<>>numerico::”+numerico+“<<>>”
@wllmdjngh
In this modified code:
  1. The teclado and numerico arrays are initialized as empty arrays.
  2. The values are only added to the arrays if the corresponding element has a valid value.
  3. The join method is used to concatenate array elements into a string with comma as a separator.
This should help you avoid creating duplicate fields with empty values in the stream.
Code:
var teclado = ;
var numerico = ;
// Process “boton_teclado_virtual” elements
// Check if the element has a valid value before adding it to the array
if (a[k].value) {
teclado.push(a[k].value);
// Process “boton_numpad_virtual” elements
if (n[j].value) {
numerico.push(n[j].value);
return “<<>>teclado::” + teclado.join(“,”) + “<<>>;<<>>numerico::” + numerico.join(“,”) + “<<>>”;
Thanks Prajakta.
Let me review the code.
Regards.
