Logic built data massaging – "Merge multiple(5 to 6) pdf’s using merge pdf plugin. Note: the merge pdf only merge 2 pdfs at a time so u need to built logic for merging multiple pdfs.
We have plugin step Merge Multiple PDFs, using this step you can merge as many pdfs as you want.
Is there any other solution to merge pdf’s dynamically as we have merge only 2 pdfs at a time.
We have plugin step Merge Multiple PDFs , using this step you can merge as many pdfs as you want.
When merging multiple PDFs, how can we determine the sequence of the merge. Based on modified date? Name order? No determined sequence?
For example, need to merge all files generated every day during the week. Merge should be in same order.
