Hello there,
I want to read the data from 3 word documents and merge that 3 files and generate a single word output file is that any plugin for this.?
Pls help
Hi ShrutikaT
There is Plugin in PS called MS Word-Mail Merge you can do this with this plugin
Thanks Akash,
But I have tried it but my word file is in paragraph format so I am not able to give the field name & field value there.
Thank you,
Okay so you follow below steps
- Mail Merge step requires one .docx template file as input So you have to give this .docx template file like for Ex. D:\Mail Merge\demo.docx
- Click on Get Fields, Field Name will automatically get filled from your Docx file
- After that select respective Field Value from the previous step/ you can hardcode it.
- Provide a path to Destination Directory , where you have to save the output file.
- After this, select Destination File Name i.e, your output filename.
Thanks
Thank you Akash
