Regarding spy
“During web automation, when I set the password value using an ID selector, the result shows undefined + password value. Why is undefined getting concatenated with the password value?”
Maybe sharing Log and/or workflow would help to understand your question.
Hi Rushikesh,
IIf you are entering the password using the GUI: Set Values plugin, it is possible that the text “undefined” is already present in the password field.
Please check whether the “Clear Text Before Set” checkbox is selected in the configuration of the GUI: Set Values plugin. Make sure this option is enabled so that any existing text is cleared and only the intended password value is entered into the field.
