In this scenario I’m validating a set of current data with previous collection of data. So in a WF I use filter rows to check if the previous provider names where the same as the current one, I have provided multiple data where it is true and false(Since the provider could have been changed previously). So instead of it being 2 separate line items one as true and other as false I wanted the out to be just false since prior to the current the provider name was different at least once.
This is the other set of current/ historic data that I’m validating against.
- The one highlighted in blue is the one that I’m using just consider the provider name in that I’ll be passing that separately on to the WF.
- The green one is where the I get the line item as true
- The red one is where it is taken as false.
This is the flow
In rename fields I pass the same fields in Get variables to only get the required data and pass that out of the WF.
What I’m looking for -
So what I want to do is instead of getting 2 different line items 1 for true and 1 for false, I want to return a single line item as false when it is false at least once in this validation.
