Run Agent in a click button
Hey everyone! How can I do it in an application, call the automation API to run the Agent after I click on a button? It’s possible? I need to run a certain robot after the user uses the application and submits it.
Thank you for the all support and help!
You can do it through RestAPI.
Request the documentation from Support.
First you need to request a TOKEN, then Execute WF, After that you can request status and restart if there was a failure, like WEB page down.
All through API.
Thank you, but how I request this TOKEN?
I didn’t understand this part
The below WF is an example on how to get the token through an API call.
Only way you can get this TOKEN.
Hope this helps.
WF_Inicialización.psw (14.6 KB)
In fact, I have a simple application, html and javascript, in this application I have a button. I need to run a workflow after this button is pressed, calling the API directly through javascript, and how do I do that?
Hi! Vinicius
Please can you refer these links and try yo implement calling API from a Java Script.
[4 Ways to Make an API Call in JavaScript ]
[html - How to call a REST web service API from JavaScript? - Stack…]
https://stackoverflow.com/questions/36975619/how-to-call-a-rest-web-service-api-from-javascript
It worked, thank you for all!
