Run linux commands plugin step issue
Cannot exit ssh command using Run Linux Commands plugin step. Getting error as “Max response timeout. Complete response not received within provided time”.
Hello Kalyani,
The below solution approach to address this issue:
  1. After starting the session, execute the “term shell” command in the “Linux: Run Linux Commands” step.
  2. This step will result in an error.
  3. Using Exception handling hop, add a new “Linux: Run Linux Commands” step and execute the desired command.
  4. It will supports a maximum length of 512 output lines. If the command output exceeds 512 lines, an error will occur.
  5. The client must utilize the exception handling mechanism demonstrated in the attached workflow to execute the commands.
Best,
Sayali K
