Text File Output Plugin
I want to pass a filename from a variable. For this I have checked “Accept file names from a field” checkbox and given my field name which is coming out from Java script. But still it gives me error as fileName field cannot be blank.. Plz check n tell….. Thank you in advance..
Try to get rid of the “.” in extension
That should do it
I have removed . from .txt.. Still the ame error
