When I hit command to shutdown agent but It is not getting shutting down. How much time required to stop agent.
How can I stop agent If I want to stop immediately.
Hi Amit,
When you run the shutdown.bat file, the agent will take normally 4-5 minute to stop the agent. You can also watch the running agent command prompt to check the agent status.
But if any process is in execution state to that agent and you run the shutdown.bat file, then it will wait till the current execution process to complete and then it will stop the agent.
thanks rakesh for this useful information.
