Web excel how to create three sheet with diffrent data
how to create 3 sheet in excel sheet
Hi Ujjwala,
Use the Excel Write where you can specify the sheet you want to write. There must be a separate Excel Write for each sheet. It can not be done with one step
One suggestion, write each sheet one after the other and not all at once. If you do, there could be unexpected results. We had a struggle when trying to do so. A true beginners experience.
Server is under maintenance now so can not create a sample WF for now. If necessary, please contact me again.
