How can we merge three excel sheets(same header with different data) in a single excel Sheet
Hi Pratik,
Yes, you can merge three excel sheet data in single excel sheet. You just have to select ‘use existing file for writing’ and ‘write to existing sheet’ in Microsoft Excel Writer plugin. Also select the checkbox ‘start writing at end of sheet (appending lines)’ and omit header in content tab.
Thanks, Suraj
Thank you Suraj.
