What is credential and credential pool
what is credential and credential pool?
Hi! Pratik
The Credential feature makes it easy to manage the credentials of external systems. Credentials are created and managed separately by a relevant authority. Workflow owners cannot see or alter user credentials; they can use them in workflow or process parameters. Process Studio process or workflow parameters have Credential as a data type. The parameters are then available as AutomaionEdge workflow configuration or runtime parameters.
A Credential Pool is a collection of credentials. Some external systems (target) allow only one active session per user at a time. Create a Credential Pool for such external systems, which would hold all the available credentials for that external system. Each workflow instance acquires a single credential from a pool at any given time. Hence, if a user wants to run multiple Workflow instances, the user can acquire multiple credentials from a credential pool.
Both the feature options are available on the AutomationEdge portal on the workflows menu.
