As i have similary value in column now i have to add the row which has similar value so which plugin to use?
Use the Group by or Memory Group by step from the Statistics category.
- Group by: Best for large datasets. Input must be sorted by the grouping field using Sort rows.
- Memory Group by: Suitable for small/medium datasets. Sorting is not required, as data is loaded into memory.
Configuration
- Add Group by or Memory Group by.
- Under Group fields, select the column whose similar values should be grouped.
- Under Aggregates:
- Count: Select Number of rows / Count.
- Sum: Select the numeric field as Subject and choose Sum.
This produces one output row for each group with the required count or total.
