After starting startup.bat from command prompt, Agent status changes to ‘Updating’ state, for so long it remains as ‘updating’ status after few minutes Its changes to unkown state.
Please let me know how could I get the agent running.
Please share the Agent log files here so we can help you with that.
I am not able to attach or upload any files. Its shows ‘Sorry ,New user cannot upload files’. So please find below agent log file details.
Agent log file-------------
A fatal error has been detected by the Java Runtime Environment:
EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x000001216bca56c4, pid=15384, tid=0x0000000000002e6c
JRE version: Java™ SE Runtime Environment (8.0_261-b12) (build 1.8.0_261-b12)
Java VM: Java HotSpot™ 64-Bit Server VM (25.261-b12 mixed mode windows-amd64 compressed oops)
Problematic frame:
C [sigar-amd64-winnt.dll+0x156c4]
Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
If you would like to submit a bug report, please visit:
Crash Report
The crash happened outside the Java Virtual Machine in native code.
See problematic frame for where to report the bug.
--------------- T H R E A D ---------------
Current thread (0x000001214fac6800): JavaThread “main” [_thread_in_native, id=11884, stack(0x000000212a100000,0x000000212a200000)]
siginfo: ExceptionCode=0xc0000005, reading address 0x000000006bed0d90
Registers:
RAX=0x000000006bed0c40, RBX=0x000001216baf5900, RCX=0x000001214fac69f8, RDX=0x000000212a1ff400
RSP=0x000000212a1ff2f0, RBP=0x000000212a1ff3e0, RSI=0x0000000040200021, RDI=0x000001215143837d
R8 =0x0000000000000032, R9 =0x00000000d9f10640, R10=0x000000000000010e, R11=0x0000000052646a1c
R12=0x0000000000000000, R13=0x000001216baf5900, R14=0x000000212a1ff400, R15=0x000001214fac6800
RIP=0x000001216bca56c4, EFLAGS=0x0000000000010202
Top of Stack: (sp=0x000000212a1ff2f0)
0x000000212a1ff2f0: 000001214fac69f8 000000212a1ff400
0x000000212a1ff300: 000001216baf5900 000001214fac6800
0x000000212a1ff310: 000000006bed0c40 000001214fac6800
0x000000212a1ff320: 000001215143837d 000001216bca5f0d
0x000000212a1ff330: 000001214fac69f8 000000212a1ff400
0x000000212a1ff340: 000001216baf5900 000001216baf5900
0x000000212a1ff350: 000001216baf5900 000001216baf5900
0x000000212a1ff360: 000001215143837d 000001215144990e
0x000000212a1ff370: 000001214fac69f8 000000212a1ff400
0x000000212a1ff380: 0000000040200021 000001214fac6800
0x000000212a1ff390: 000000212a1ff458 00000121514495c2
0x000000212a1ff3a0: 000000212a1ff3a0 000001216baf5900
0x000000212a1ff3b0: 000000212a1ff400 000001216bafb410
0x000000212a1ff3c0: 0000000000000000 000001216baf5900
0x000000212a1ff3d0: 0000000000000000 000000212a1ff400
0x000000212a1ff3e0: 000000212a1ff448 0000012151437e90
Instructions: (pc=0x000001216bca56c4)
0x000001216bca56a4: 7c 24 20 00 75 15 48 8d 15 9f f2 03 00 48 8b 4c
0x000001216bca56b4: 24 40 e8 45 00 00 00 33 c0 eb 32 48 8b 44 24 20
0x000001216bca56c4: 83 b8 50 01 00 00 00 74 1f 48 8b 44 24 20 44 8b
0x000001216bca56d4: 80 50 01 00 00 48 8b 54 24 20 48 8b 4c 24 40 e8
Register to memory mapping:
RAX=0x000000006bed0c40 is an unknown value
RBX={method} {0x000001216baf5908} ‘getPid’ ‘()J’ in ‘org/hyperic/sigar/Sigar’
RCX=0x000001214fac69f8 is an unknown value
RDX=0x000000212a1ff400 is pointing into the stack for thread: 0x000001214fac6800
RSP=0x000000212a1ff2f0 is pointing into the stack for thread: 0x000001214fac6800
RBP=0x000000212a1ff3e0 is pointing into the stack for thread: 0x000001214fac6800
RSI=0x0000000040200021 is an unknown value
RDI=0x000001215143837d is at code_begin+2301 in an Interpreter codelet
invoke return entry points [0x0000012151437a80, 0x0000012151438460] 2528 bytes
R8 =0x0000000000000032 is an unknown value
R9 =0x00000000d9f10640 is an oop
org.hyperic.sigar.Sigar
- klass: ‘org/hyperic/sigar/Sigar’
R10=0x000000000000010e is an unknown value
R11=0x0000000052646a1c is an unknown value
R12=0x0000000000000000 is an unknown value
R13={method} {0x000001216baf5908} ‘getPid’ ‘()J’ in ‘org/hyperic/sigar/Sigar’
R14=0x000000212a1ff400 is pointing into the stack for thread: 0x000001214fac6800
R15=0x000001214fac6800 is a thread
Stack: [0x000000212a100000,0x000000212a200000], sp=0x000000212a1ff2f0, free space=1020k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
C [sigar-amd64-winnt.dll+0x15f0d]
C 0x000001215144990e
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j org.hyperic.sigar.Sigar.getPid()J+0
j com.automationedge.util.SystemUsage.()V+22
j com.automationedge.aeagent.core.handlers.AgentSystemMonitoringThread.()V+15
j com.automationedge.aeagent.core.handlers.AgentThreadHandler.startSystemMonitoringThread()V+5
j com.automationedge.aeagent.core.handlers.AgentThreadHandler.start(Ljava/lang/Integer;Ljava/lang/Integer;)V+76
j com.automationedge.aeagent.AgentMain.startAgent(Lcom/automationedge/enums/AgentStartupMode;)V+200
j com.automationedge.aeagent.AgentMain.main([Ljava/lang/String;)V+203
v ~StubRoutines::call_stub
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x0000012168ec7000 JavaThread “Thread-10” daemon [_thread_in_native, id=14104, stack(0x000000212c100000,0x000000212c200000)]
0x00000121693ef800 JavaThread “Thread-9” [_thread_in_native, id=8232, stack(0x000000212c000000,0x000000212c100000)]
0x0000012168822800 JavaThread “pool-2-thread-1” [_thread_blocked, id=11240, stack(0x000000212bf00000,0x000000212c000000)]
0x0000012168821800 JavaThread “Thread-8” [_thread_blocked, id=2388, stack(0x000000212be00000,0x000000212bf00000)]
0x000001216a3c7800 JavaThread “Thread-7” [_thread_blocked, id=8880, stack(0x000000212bd00000,0x000000212be00000)]
0x000001216a3c6800 JavaThread “Thread-6” [_thread_blocked, id=8100, stack(0x000000212bc00000,0x000000212bd00000)]
0x00000121685aa000 JavaThread “org.apache.commons.vfs2.cache.SoftRefFilesCache$SoftRefReleaseThread” daemon [_thread_blocked, id=11492, stack(0x000000212bb00000,0x000000212bc00000)]
0x00000121687d9000 JavaThread “Timer-0” daemon [_thread_blocked, id=12116, stack(0x000000212ba00000,0x000000212bb00000)]
0x00000121689aa000 JavaThread “Log4j2-TF-3-Scheduled-1” daemon [_thread_blocked, id=836, stack(0x000000212b500000,0x000000212b600000)]
0x0000012167b80800 JavaThread “Service Thread” daemon [_thread_blocked, id=11424, stack(0x000000212b300000,0x000000212b400000)]
0x00000121667d6800 JavaThread “C1 CompilerThread3” daemon [_thread_blocked, id=4308, stack(0x000000212b200000,0x000000212b300000)]
0x00000121667d0800 JavaThread “C2 CompilerThread2” daemon [_thread_blocked, id=10532, stack(0x000000212b100000,0x000000212b200000)]
0x00000121667c8000 JavaThread “C2 CompilerThread1” daemon [_thread_blocked, id=15648, stack(0x000000212b000000,0x000000212b100000)]
0x00000121667c2000 JavaThread “C2 CompilerThread0” daemon [_thread_blocked, id=13536, stack(0x000000212af00000,0x000000212b000000)]
0x00000121667be000 JavaThread “Attach Listener” daemon [_thread_blocked, id=15092, stack(0x000000212ae00000,0x000000212af00000)]
0x00000121667c7800 JavaThread “Signal Dispatcher” daemon [_thread_blocked, id=13196, stack(0x000000212ad00000,0x000000212ae00000)]
0x00000121667a0000 JavaThread “Finalizer” daemon [_thread_blocked, id=13908, stack(0x000000212ac00000,0x000000212ad00000)]
0x0000012166779800 JavaThread “Reference Handler” daemon [_thread_blocked, id=8692, stack(0x000000212ab00000,0x000000212ac00000)]
=>0x000001214fac6800 JavaThread “main” [_thread_in_native, id=11884, stack(0x000000212a100000,0x000000212a200000)]
Other Threads:
0x0000012166771800 VMThread [stack: 0x000000212aa00000,0x000000212ab00000] [id=13480]
0x0000012167bca000 WatcherThread [stack: 0x000000212b400000,0x000000212b500000] [id=10472]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
heap address: 0x0000000080000000, size: 2048 MB, Compressed Oops mode: 32-bit
Narrow klass base: 0x0000000000000000, Narrow klass shift: 3
Compressed class space size: 1073741824 Address: 0x0000000100000000
Heap:
PSYoungGen total 305664K, used 89113K [0x00000000d5580000, 0x00000000eaa80000, 0x0000000100000000)
eden space 262144K, 33% used [0x00000000d5580000,0x00000000dac865d0,0x00000000e5580000)
from space 43520K, 0% used [0x00000000e5580000,0x00000000e5580000,0x00000000e8000000)
to space 43520K, 0% used [0x00000000e8000000,0x00000000e8000000,0x00000000eaa80000)
ParOldGen total 699392K, used 16171K [0x0000000080000000, 0x00000000aab00000, 0x00000000d5580000)
object space 699392K, 2% used [0x0000000080000000,0x0000000080fcadb0,0x00000000aab00000)
Metaspace used 27152K, capacity 27382K, committed 27776K, reserved 1073152K
class space used 3344K, capacity 3425K, committed 3456K, reserved 1048576K
Card table byte_map: [0x00000121607f0000,0x0000012160c00000] byte_map_base: 0x00000121603f0000
Marking Bits: (ParMarkBitMap*) 0x0000000052654fb0
Begin Bits: [0x0000012160eb0000, 0x0000012162eb0000)
End Bits: [0x0000012162eb0000, 0x0000012164eb0000)
Polling page: 0x000001214fa50000
CodeCache: size=245760Kb used=7066Kb max_used=7778Kb free=238693Kb
bounds [0x0000012151430000, 0x0000012151be0000, 0x0000012160430000]
total_blobs=2678 nmethods=2164 adapters=427
compilation: enabled
Compilation events (10 events):
Event: 20.363 Thread 0x00000121667d0800 2350 4 java.util.LinkedHashMap::afterNodeInsertion (40 bytes)
Event: 20.364 Thread 0x00000121667d6800 2348 3 com.fasterxml.jackson.databind.introspect.POJOPropertyBuilder::fromMemberAnnotations (125 bytes)
Event: 20.365 Thread 0x00000121667d6800 nmethod 2348 0x000001215154fcd0 code [0x000001215154fec0, 0x0000012151550940]
Event: 20.365 Thread 0x00000121667d6800 2349 3 com.fasterxml.jackson.databind.introspect.AnnotatedClass::getAnnotation (11 bytes)
Event: 20.366 Thread 0x00000121667d6800 nmethod 2349 0x0000012151561b10 code [0x0000012151561c80, 0x0000012151561eb0]
Event: 20.366 Thread 0x00000121667d6800 2345 3 com.fasterxml.jackson.databind.introspect.AnnotatedWithParams:: (12 bytes)
Event: 20.366 Thread 0x00000121667d6800 nmethod 2345 0x0000012151752010 code [0x0000012151752180, 0x0000012151752438]
Event: 20.367 Thread 0x00000121667d6800 2347 3 com.fasterxml.jackson.databind.introspect.POJOPropertyBuilder::_trimByVisibility (11 bytes)
Event: 20.367 Thread 0x00000121667d6800 nmethod 2347 0x000001215155ed10 code [0x000001215155ee80, 0x000001215155f0f0]
Event: 20.369 Thread 0x00000121667d0800 nmethod 2350 0x00000121516c4b90 code [0x00000121516c4ce0, 0x00000121516c4e68]
GC Heap History (4 events):
Event: 14.451 GC heap before
{Heap before GC invocations=1 (full 0):
PSYoungGen total 305664K, used 162551K [0x00000000d5580000, 0x00000000eaa80000, 0x0000000100000000)
eden space 262144K, 62% used [0x00000000d5580000,0x00000000df43dee8,0x00000000e5580000)
from space 43520K, 0% used [0x00000000e8000000,0x00000000e8000000,0x00000000eaa80000)
to space 43520K, 0% used [0x00000000e5580000,0x00000000e5580000,0x00000000e8000000)
ParOldGen total 699392K, used 0K [0x0000000080000000, 0x00000000aab00000, 0x00000000d5580000)
object space 699392K, 0% used [0x0000000080000000,0x0000000080000000,0x00000000aab00000)
Metaspace used 20832K, capacity 21058K, committed 21296K, reserved 1069056K
class space used 2543K, capacity 2635K, committed 2688K, reserved 1048576K
Event: 14.487 GC heap after
Heap after GC invocations=1 (full 0):
PSYoungGen total 305664K, used 16988K [0x00000000d5580000, 0x00000000eaa80000, 0x0000000100000000)
eden space 262144K, 0% used [0x00000000d5580000,0x00000000d5580000,0x00000000e5580000)
from space 43520K, 39% used [0x00000000e5580000,0x00000000e6617338,0x00000000e8000000)
ParOldGen total 699392K, used 96K [0x0000000080000000, 0x00000000aab00000, 0x00000000d5580000)
object space 699392K, 0% used [0x0000000080000000,0x0000000080018028,0x00000000aab00000)
Event: 14.487 GC heap before
{Heap before GC invocations=2 (full 1):
Event: 14.563 GC heap after
Heap after GC invocations=2 (full 1):
PSYoungGen total 305664K, used 0K [0x00000000d5580000, 0x00000000eaa80000, 0x0000000100000000)
Deoptimization events (10 events):
Event: 16.942 Thread 0x000001214fac6800 Uncommon trap: reason=class_check action=maybe_recompile pc=0x0000012151a4e75c method=sun.security.util.math.intpoly.IntegerPolynomial$MutableElement.setSum(Lsun/security/util/math/IntegerModuloP;)Lsun/security/util/math/intpoly/IntegerPolynomial$MutableE
Event: 17.076 Thread 0x000001214fac6800 Uncommon trap: reason=unstable_if action=reinterpret pc=0x00000121519d2864 method=java.util.Arrays.equals([B[B)Z @ 12
Event: 17.127 Thread 0x000001214fac6800 Uncommon trap: reason=unstable_if action=reinterpret pc=0x0000012151a102c0 method=java.util.concurrent.ConcurrentHashMap.putVal(Ljava/lang/Object;Ljava/lang/Object;Z)Ljava/lang/Object; @ 206
Event: 17.343 Thread 0x000001214fac6800 Uncommon trap: reason=unstable_if action=reinterpret pc=0x00000121518ec5a4 method=java.lang.CharacterDataLatin1.digit(II)I @ 60
Event: 17.995 Thread 0x000001214fac6800 Uncommon trap: reason=unstable_if action=reinterpret pc=0x00000121516aa2bc method=java.lang.AbstractStringBuilder.append(Ljava/lang/String;)Ljava/lang/AbstractStringBuilder; @ 1
Event: 18.516 Thread 0x000001214fac6800 Uncommon trap: reason=unstable_if action=reinterpret pc=0x00000121516ec744 method=java.util.ArrayList.rangeCheck(I)V @ 5
Event: 18.695 Thread 0x000001214fac6800 Uncommon trap: reason=unstable_if action=reinterpret pc=0x0000012151b376a8 method=org.apache.xerces.dom.ParentNode.nodeListItem(I)Lorg/w3c/dom/Node; @ 115
Event: 18.696 Thread 0x000001214fac6800 Uncommon trap: reason=unstable_if action=reinterpret pc=0x0000012151b48de8 method=org.apache.xerces.dom.ParentNode.nodeListItem(I)Lorg/w3c/dom/Node; @ 115
Event: 18.753 Thread 0x000001214fac6800 Uncommon trap: reason=unstable_if action=reinterpret pc=0x0000012151b5e984 method=java.util.Properties$LineReader.readLine()I @ 174
Event: 18.806 Thread 0x000001214fac6800 Uncommon trap: reason=unstable_if action=reinterpret pc=0x0000012151b5a828 method=org.apache.xerces.impl.XMLEntityScanner.scanContent(Lorg/apache/xerces/xni/XMLString;)I @ 43
Classes redefined (0 events):
No events
Internal exceptions (10 events):
Event: 13.713 Thread 0x000001214fac6800 Exception <a ‘java/lang/UnsatisfiedLinkError’: The specified procedure could not be found.
(0x00000000de97d330) thrown at [C:\jenkins\workspace\8-2-build-windows-amd64-cygwin\jdk8u261\295\hotspot\src\share\vm\prims\jni.cpp, line 737]
Event: 13.738 Thread 0x000001214fac6800 Exception <a ‘java/lang/UnsatisfiedLinkError’: The specified procedure could not be found.
(0x00000000de9bcfb8) thrown at [C:\jenkins\workspace\8-2-build-windows-amd64-cygwin\jdk8u261\295\hotspot\src\share\vm\prims\jni.cpp, line 737]
Event: 13.743 Thread 0x000001214fac6800 Exception <a ‘java/lang/UnsatisfiedLinkError’: The specified procedure could not be found.
(0x00000000de9dffa8) thrown at [C:\jenkins\workspace\8-2-build-windows-amd64-cygwin\jdk8u261\295\hotspot\src\share\vm\prims\jni.cpp, line 737]
Event: 13.751 Thread 0x000001214fac6800 Exception <a ‘com/sun/jna/LastErrorException’: [12180] > (0x00000000de9e1108) thrown at [C:\jenkins\workspace\8-2-build-windows-amd64-cygwin\jdk8u261\295\hotspot\src\share\vm\prims\jni.cpp, line 737]
Event: 15.010 Thread 0x00000121667a0000 Exception <a ‘java/lang/Error’: Invalid memory access> (0x00000000d5a4a350) thrown at [C:\jenkins\workspace\8-2-build-windows-amd64-cygwin\jdk8u261\295\hotspot\src\share\vm\prims\jni.cpp, line 737]
Event: 17.076 Thread 0x000001214fac6800 Implicit null exception at 0x00000121519d26f8 to 0x00000121519d2851
Event: 17.343 Thread 0x000001214fac6800 Exception <a ‘com/sun/jna/LastErrorException’: [12180] > (0x00000000d7a47128) thrown at [C:\jenkins\workspace\8-2-build-windows-amd64-cygwin\jdk8u261\295\hotspot\src\share\vm\prims\jni.cpp, line 737]
Event: 17.988 Thread 0x000001214fac6800 Exception <a ‘java/io/FileNotFoundException’> (0x00000000d8098b58) thrown at [C:\jenkins\workspace\8-2-build-windows-amd64-cygwin\jdk8u261\295\hotspot\src\share\vm\prims\jni.cpp, line 710]
Event: 17.995 Thread 0x000001214fac6800 Implicit null exception at 0x00000121516a9f16 to 0x00000121516aa2a5
Event: 18.877 Thread 0x00000121693ef800 Exception <a ‘com/sun/jna/LastErrorException’: [12180] > (0x00000000da5e13b8) thrown at [C:\jenkins\workspace\8-2-build-windows-amd64-cygwin\jdk8u261\295\hotspot\src\share\vm\prims\jni.cpp, line 737]
Events (10 events):
Event: 20.368 Executing VM operation: RevokeBias
Event: 20.368 Executing VM operation: RevokeBias done
Event: 20.368 Executing VM operation: BulkRevokeBias
Event: 20.369 Executing VM operation: BulkRevokeBias done
Event: 20.369 Thread 0x00000121667d0800 flushing nmethod 0x000001215182ad10
Event: 20.369 Thread 0x00000121667d0800 flushing nmethod 0x000001215186b950
Event: 20.369 Thread 0x00000121667d0800 flushing nmethod 0x000001215186d010
Event: 20.370 loading class java/util/function/UnaryOperator
Event: 20.370 loading class java/util/function/UnaryOperator done
Event: 20.370 loading class java/io/ObjectOutputStream
Dynamic libraries:
0x00007ff6f6ed0000 - 0x00007ff6f6f17000 C:\Program Files (x86)\Common Files\Oracle\Java\javapath\java.exe
0x00007ffe2e6b0000 - 0x00007ffe2e8a6000 C:\WINDOWS\SYSTEM32\ntdll.dll
0x00007ffe2def0000 - 0x00007ffe2dfad000 C:\WINDOWS\System32\KERNEL32.DLL
0x00007ffe2c130000 - 0x00007ffe2c3f8000 C:\WINDOWS\System32\KERNELBASE.dll
0x00007ffe2dd30000 - 0x00007ffe2ddda000 C:\WINDOWS\System32\ADVAPI32.dll
0x00007ffe2d7e0000 - 0x00007ffe2d87e000 C:\WINDOWS\System32\msvcrt.dll
0x00007ffe2dde0000 - 0x00007ffe2de7b000 C:\WINDOWS\System32\sechost.dll
0x00007ffe2dc00000 - 0x00007ffe2dd24000 C:\WINDOWS\System32\RPCRT4.dll
0x00007ffe2d640000 - 0x00007ffe2d7e0000 C:\WINDOWS\System32\USER32.dll
0x00007ffe2c000000 - 0x00007ffe2c022000 C:\WINDOWS\System32\win32u.dll
0x00007ffe2e040000 - 0x00007ffe2e06a000 C:\WINDOWS\System32\GDI32.dll
0x00007ffe2c430000 - 0x00007ffe2c539000 C:\WINDOWS\System32\gdi32full.dll
0x00007ffe2bf00000 - 0x00007ffe2bf9d000 C:\WINDOWS\System32\msvcp_win.dll
0x00007ffe2c030000 - 0x00007ffe2c130000 C:\WINDOWS\System32\ucrtbase.dll
0x00007ffe1c9b0000 - 0x00007ffe1cc4b000 C:\WINDOWS\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.19041.488_none_ca04af081b815d21\COMCTL32.dll
0x00007ffe2dbd0000 - 0x00007ffe2dc00000 C:\WINDOWS\System32\IMM32.DLL
0x00007ffdfb530000 - 0x00007ffdfb545000 C:\Program Files\Java\jre1.8.0_261\bin\vcruntime140.dll
0x00007ffdfa090000 - 0x00007ffdfa12b000 C:\Program Files\Java\jre1.8.0_261\bin\msvcp140.dll
0x0000000051e60000 - 0x00000000526cc000 C:\Program Files\Java\jre1.8.0_261\bin\server\jvm.dll
0x00007ffe2dae0000 - 0x00007ffe2dae8000 C:\WINDOWS\System32\PSAPI.DLL
0x00007ffe1d2b0000 - 0x00007ffe1d2d7000 C:\WINDOWS\SYSTEM32\WINMM.dll
0x00007ffe26b10000 - 0x00007ffe26b1a000 C:\WINDOWS\SYSTEM32\VERSION.dll
0x00007ffe28980000 - 0x00007ffe28989000 C:\WINDOWS\SYSTEM32\WSOCK32.dll
0x00007ffe2de80000 - 0x00007ffe2deeb000 C:\WINDOWS\System32\WS2_32.dll
0x00007ffe29c40000 - 0x00007ffe29c52000 C:\WINDOWS\SYSTEM32\kernel.appcore.dll
0x00007ffe254a0000 - 0x00007ffe254b0000 C:\Program Files\Java\jre1.8.0_261\bin\verify.dll
0x00007ffdfb430000 - 0x00007ffdfb45b000 C:\Program Files\Java\jre1.8.0_261\bin\java.dll
0x00007ffdfa4c0000 - 0x00007ffdfa4d8000 C:\Program Files\Java\jre1.8.0_261\bin\zip.dll
0x00007ffe2c720000 - 0x00007ffe2ce60000 C:\WINDOWS\System32\SHELL32.dll
0x00007ffe29f50000 - 0x00007ffe2a6e4000 C:\WINDOWS\SYSTEM32\windows.storage.dll
0x00007ffe2ce60000 - 0x00007ffe2d1b5000 C:\WINDOWS\System32\combase.dll
0x00007ffe2b7a0000 - 0x00007ffe2b7cc000 C:\WINDOWS\SYSTEM32\Wldp.dll
0x00007ffe2e070000 - 0x00007ffe2e11e000 C:\WINDOWS\System32\SHCORE.dll
0x00007ffe2daf0000 - 0x00007ffe2db45000 C:\WINDOWS\System32\shlwapi.dll
0x00007ffe2bd30000 - 0x00007ffe2bd56000 C:\WINDOWS\SYSTEM32\profapi.dll
0x00007ffe253e0000 - 0x00007ffe253ed000 C:\Program Files\Java\jre1.8.0_261\bin\management.dll
0x00007ffdfa180000 - 0x00007ffdfa19c000 C:\Program Files\Java\jre1.8.0_261\bin\net.dll
0x00007ffe2b520000 - 0x00007ffe2b58a000 C:\WINDOWS\system32\mswsock.dll
0x00007ffdf7910000 - 0x00007ffdf7927000 C:\WINDOWS\system32\napinsp.dll
0x00007ffdf78f0000 - 0x00007ffdf790b000 C:\WINDOWS\system32\pnrpnsp.dll
0x00007ffe27490000 - 0x00007ffe274ad000 C:\WINDOWS\system32\NLAapi.dll
0x00007ffe2b210000 - 0x00007ffe2b24b000 C:\WINDOWS\SYSTEM32\IPHLPAPI.DLL
0x00007ffe2b2a0000 - 0x00007ffe2b36b000 C:\WINDOWS\SYSTEM32\DNSAPI.dll
0x00007ffe2d880000 - 0x00007ffe2d889000 C:\WINDOWS\System32\NSI.dll
0x00007ffe0e010000 - 0x00007ffe0e025000 C:\WINDOWS\system32\wshbth.dll
0x00007ffdf78d0000 - 0x00007ffdf78e2000 C:\WINDOWS\System32\winrnr.dll
0x00007ffe1f870000 - 0x00007ffe1f87a000 C:\Windows\System32\rasadhlp.dll
0x00007ffe21990000 - 0x00007ffe21a0f000 C:\WINDOWS\System32\fwpuclnt.dll
0x00007ffe2c400000 - 0x00007ffe2c427000 C:\WINDOWS\System32\bcrypt.dll
0x00007ffdf9710000 - 0x00007ffdf9723000 C:\Program Files\Java\jre1.8.0_261\bin\nio.dll
0x00007ffe256d0000 - 0x00007ffe256e7000 C:\WINDOWS\SYSTEM32\dhcpcsvc6.DLL
0x00007ffe258f0000 - 0x00007ffe2590d000 C:\WINDOWS\SYSTEM32\dhcpcsvc.DLL
0x00007ffe2b6f0000 - 0x00007ffe2b708000 C:\WINDOWS\SYSTEM32\CRYPTSP.dll
0x00007ffe2aeb0000 - 0x00007ffe2aee4000 C:\WINDOWS\system32\rsaenh.dll
0x00007ffe2bc80000 - 0x00007ffe2bcae000 C:\WINDOWS\SYSTEM32\USERENV.dll
0x00007ffe2c540000 - 0x00007ffe2c5bf000 C:\WINDOWS\System32\bcryptprimitives.dll
0x00007ffe2b710000 - 0x00007ffe2b71c000 C:\WINDOWS\SYSTEM32\CRYPTBASE.dll
0x0000000180000000 - 0x0000000180038000 C:\Users\onkar\AppData\Local\Temp\jna-105893789\jna8383962528306239459.dll
0x00007ffe21a10000 - 0x00007ffe21b10000 C:\WINDOWS\SYSTEM32\winhttp.dll
0x00007ffe22660000 - 0x00007ffe22684000 C:\Program Files\Java\jre1.8.0_261\bin\sunec.dll
0x00007ffe24cf0000 - 0x00007ffe24cfd000 C:\Program Files\Java\jre1.8.0_261\bin\sunmscapi.dll
0x00007ffe2c5c0000 - 0x00007ffe2c71d000 C:\WINDOWS\System32\CRYPT32.dll
0x00007ffe2b810000 - 0x00007ffe2b837000 C:\WINDOWS\SYSTEM32\ncrypt.dll
0x00007ffe2b7d0000 - 0x00007ffe2b80b000 C:\WINDOWS\SYSTEM32\NTASN1.dll
0x000001216bc90000 - 0x000001216bcf9000 D:\AE\ae-agent\native\sigar-amd64-winnt.dll
0x00007ffe2e2d0000 - 0x00007ffe2e3fa000 C:\WINDOWS\System32\ole32.dll
0x00007ffe2e480000 - 0x00007ffe2e54d000 C:\WINDOWS\System32\OLEAUT32.dll
0x00007ffe1d1a0000 - 0x00007ffe1d1e9000 C:\WINDOWS\SYSTEM32\pdh.dll
0x00007ffe1a0e0000 - 0x00007ffe1a0f8000 C:\WINDOWS\SYSTEM32\NETAPI32.dll
0x00007ffe2b370000 - 0x00007ffe2b37c000 C:\WINDOWS\SYSTEM32\NETUTILS.DLL
0x00007ffe290e0000 - 0x00007ffe29108000 C:\WINDOWS\SYSTEM32\SRVCLI.DLL
0x00007ffe1b470000 - 0x00007ffe1b654000 C:\WINDOWS\SYSTEM32\dbghelp.dll
VM Arguments:
jvm_args: -XX:MaxMetaspaceSize=128m -Xss1m -Xms1024m -Xmx2048m -Daeagent.home=D:\AE\ae-agent\bin\.. -Dapp.name=aeagent -Dapp.repo=D:\AE\ae-agent\bin\..\lib -Dapp.home=D:\AE\ae-agent\bin\.. -Dbasedir=D:\AE\ae-agent\bin\.. -Duser.dir=D:\AE\ae-agent\bin\..
java_command: com.automationedge.aeagent.AgentMain
java_class_path (initial): D:\AE\ae-agent\bin\..\conf;D:\AE\ae-agent\bin\..\etc;D:\AE\ae-agent\bin\..\lib\activation-1.1.1.jar;D:\AE\ae-agent\bin\..\lib\adapterframework-5.6.2.jar;D:\AE\ae-agent\bin\..\lib\ae-ootb-adapters-5.6.2.jar;D:\AE\ae-agent\bin\..\lib\aeagent-5.6.2.jar;D:\AE\ae-agent\bin\..\lib\aemodel-5.6.2.jar;D:\AE\ae-agent\bin\..\lib\aeutils-5.6.2.jar;D:\AE\ae-agent\bin\..\lib\antisamy-1.5.7.jar;D:\AE\ae-agent\bin\..\lib\auditlog-models-5.6.0.jar;D:\AE\ae-agent\bin\..\lib\batik-anim-1.10.jar;D:\AE\ae-agent\bin\..\lib\batik-awt-util-1.10.jar;D:\AE\ae-agent\bin\..\lib\batik-bridge-1.10.jar;D:\AE\ae-agent\bin\..\lib\batik-codec-1.10.jar;D:\AE\ae-agent\bin\..\lib\batik-constants-1.10.jar;D:\AE\ae-agent\bin\..\lib\batik-css-1.10.jar;D:\AE\ae-agent\bin\..\lib\batik-dom-1.10.jar;D:\AE\ae-agent\bin\..\lib\batik-ext-1.10.jar;D:\AE\ae-agent\bin\..\lib\batik-gvt-1.10.jar;D:\AE\ae-agent\bin\..\lib\batik-i18n-1.10.jar;D:\AE\ae-agent\bin\..\lib\batik-parser-1.10.jar;D:\AE\ae-agent\bin\..\lib\batik-script-1.10.jar;D:\AE\ae-agent\bin\..\lib\batik-svg-dom-1.10.jar;D:\AE\ae-agent\bin\..\lib\batik-svggen-1.10.jar;D:\AE\ae-agent\bin\..\lib\batik-transcoder-1.10.jar;D:\AE\ae-agent\bin\..\lib\batik-util-1.10.jar;D:\AE\ae-agent\bin\..\lib\batik-xml-1.10.jar;D:\AE\ae-agent\bin\..\lib\bsh-core-2.0b4.jar;D:\AE\ae-agent\bin\..\lib\c3p0-0.9.5-pre5.jar;D:\AE\ae-agent\bin\..\lib\cglib-nodep-2.1_3.jar;D:\AE\ae-agent\bin\..\lib\common-external-5.6.0.jar;D:\AE\ae-agent\bin\..\lib\common-models-5.6.0.jar;D:\AE\ae-agent\bin\..\lib\common-utils-5.6.0.jar;D:\AE\ae-agent\bin\..\lib\commons-beanutils-1.9.3.jar;D:\AE\ae-agent\bin\..\lib\commons-cli-1.4.jar;D:\AE\ae-agent\bin\..\lib\commons-codec-1.9.jar;D:\AE\ae-agent\bin\..\lib\commons-collections-3.2.2.jar;D:\AE\ae-agent\bin\..\lib\commons-collections4-4.1.jar;D:\AE\ae-agent\bin\..\lib\commons-compiler-3.0.6.jar;D:\AE\ae-agent\bin\..\lib\commons-compress-1.17.jar;D:\AE\ae-agent\bin\..\lib\commons-con
Launcher Type: SUN_STANDARD
Environment Variables:
JAVA_HOME=C:\Program Files\Java\jdk1.8.0_92
JRE_HOME=C:\Program Files\Java\jre1.8.0_261
CLASSPATH=“D:\AE\ae-agent\bin\..”\conf;“D:\AE\ae-agent\bin\..”\etc;“D:\AE\ae-agent\bin\..\lib”*;“D:\AE\ae-agent\bin\..”\lib_ext*
PATH=C:\Program Files (x86)\Common Files\Oracle\Java\javapath;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0;C:\Windows\System32\OpenSSH;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0;C:\WINDOWS\System32\OpenSSH;C:\Users\onkar\AppData\Local\Microsoft\WindowsApps;C:\python\Scripts;C:\Program Files\jdk-15\bin;“C:\Program Files\Java\jdk1.8.0_92\bin;C:\Program Files\Java\jre1.8.0_261\bin;”;
USERNAME=onkar
OS=Windows_NT
PROCESSOR_IDENTIFIER=AMD64 Family 23 Model 24 Stepping 1, AuthenticAMD
--------------- S Y S T E M ---------------
OS: Windows 10.0 , 64 bit Build 19041 (10.0.19041.546)
CPU:total 8 (initial active 8) (8 cores per cpu, 1 threads per core) family 23 model 24 stepping 1, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3, sse4.1, sse4.2, popcnt, avx, avx2, aes, clmul, mmxext, 3dnowpref, lzcnt, sse4a, tsc, tscinvbit, tscinv, bmi1
Memory: 4k page, physical 6227300k(830528k free), swap 12447120k(2169212k free)
vm_info: Java HotSpot™ 64-Bit Server VM (25.261-b12) for windows-amd64 JRE (1.8.0_261-b12), built on Jun 18 2020 06:56:32 by “” with unknown MS VC++:1916
time: Thu Oct 29 19:14:58 2020
timezone: India Standard Time
elapsed time: 20 seconds (0d 0h 0m 20s)
