In the trial version of AE, i dont have “Web GUI” steps. So to proceed can we import it from anywhere?
Are you using local(on prim) instance of AE or on-cloud instance of AE?
Web GUI plugins will be available with trial license in both the cases after sync plugin option.
- For On prim instance - you need to upload Web GUI plugins with sysadmin login and the it will be available in PS after sync plugin option.
- For On Cloud instance - You need to do sync plugins properly.
Can you give step how to do this?, Because In mysystem WEB GUI step is not visible even after “sync plugin”
HI @Shubhamautomation,
Welcome to the AutomationEgde Community. I would like to ask you the same question as Rohini. Do you have a cloud setup (T3) or OnPrem setup?
Thank you for your reply
My problem solved now ,
plugin was not getting upated due to internet connection, now it’s working fine and all the plugin are available in pane.
Good to know Shubham! Feel free to reach out to us in case of any issues! Good luck for your automation journey!
