Emmanuel Katto : Error Parsing JSON in AutomationEdge UI: Need Help with Workflow Creation and Updates
Hello Everyone,
I’m Emmanuel Katto, running a bags manufacturing business, and I’ve encountered a problem while trying to create and update workflows on the AutomationEdge UI. Each time I try to modify or create a workflow, I receive an error, and the following message appears in the logs:
2020-03-11 15:44:00 http-nio-8080-exec-2 ERROR RESTInputValidator:56 - Error parsing restvalidation.json
com.fasterxml.jackson.databind.JsonMappingException: Unexpected character (‘"’ (code 34)): was expecting comma to separate Object entries
From what I understand, there seems to be an issue with parsing the JSON file, possibly due to a formatting error. However, I’m unsure of the exact cause or how to fix it.
Has anyone else faced a similar issue? If so, could you please share how you resolved it or suggest any troubleshooting steps I can follow to fix this JSON parsing error?
I’m looking forward to your suggestions and advice. Any help would be greatly appreciated!
Thank you in advance for your support!
Regards
Emmanuel Katto
