Error in Execute Python Script Step
When I try to run python script step (Simple script only) it is showing java.lang.NullPointerException. but if I run the same WF from AE portal through Agent, it’s working.
And I am unable to run python script in any other workflows also.
Could you please help me in solving this?
Thanks,
Ramesh
Hello Ramesh,
Could you please share your workflow? We will check it from our end and let you know.
test.zip (2.6 KB)
Please find the workflow
I am getting the same for all “python script step”
And, Now I am not able to run any workflows having Python script from both process studio and AE Portal… Please help here to sort this issue out.
Could you please update on this?
The workflow is working in our environment. Please update the AE version to 5.6.x or above. Attached are the screenshots for your reference.
