How can we access the shared database connection in another project?
I have created a shared database connection for one project, but when I switch the project, I am not able to see the same db connection in another project, how can we access the same connection in another project as well?
In AutomationEdge Process Studio, a “Shared Database Connection” is scoped at the Project level rather than globally across the entire workspace. When you create or share a database connection in a project, it is stored in that project’s Connections folder so that all workflows and processes within that specific project can reuse it. However, it remains isolated from other projects.
Here is how you can access or reuse the same database connection-
  1. Open the workflow, navigate to the View tab in the left pane, and expand Database connections.
  2. Right-click the local connection and select Share
