How to Ping Multiple Ip Address using "PING A HOST"
I want to ping 10 to 15 Ip addresses based on connectivity. I want to create an excel file with the respective Ip address and status.
Hi! Ava,
You can use the Excel Input step to read your excel file containing the list of IP addresses. Then in the Ping a Host, select the column name for the Host IP from the drop down list. In this way it will ping all the hosts in the list.
