How to deploy a project from Process Studio to AutomationEdge Server?
To publish a workflow to AutomationEdge Server for the first time:
In Process Studio, select File → Publish → Create, or right-click the project in Project Explorer and select Publish → Create.
Confirm your AE Server credentials if prompted.
If the workflow uses external resources (e.g., Excel files, CSVs, or scripts), select Add supporting file(s) to ZIP archive and click Yes.
In the Workflow Details dialog, configure the workflow name, description, and category. Enable Assisted or RDP enabled if required.
Select Set default value(s) as configuration parameter value(s) if you want design-time default values to be carried over to server configuration parameters.
Click Create. A success message confirms that the workflow has been published.
