Question regarding workflow categories
Hi Team,
I have a question regarding workflow categories in AutomationEdge.
Once a workflow is deployed from Process Studio with a default category, is it possible to change the category later from the server side? I tried updating it, but the change didn’t reflect and it is disabled there.
Is this expected behavior, or is there a way to modify the category after deployment?
Please below steps to change category on AutomationEdge Server:
  1. Go to Workflow Menu-Category Sub menu
  2. Select the workflow which you want to move from default category
  3. Select the category in which you wish to move the workflow
  4. Click on Move
Your workflow will be move to another category and will no longer be available in default category.
