Unable to dynamically update “Service Name” header while generating service-wise Excel reports
Hi everyone,
I am working on generating service-wise Excel reports in a predefined format. The report structure includes fields like WO, District, Technician, Total Cost, and a header section where I need to display the Service Name (e.g., Assess, Deliver, Install, Repair and Replace).
I am able to:
Place all tabular data dynamically
Calculate totals correctly
Generate separate files per service
However, I am facing an issue with dynamically updating the “Service Name” field in the header (Cell B1). See the reference Picture
The service name exists in a different dataset/column, and while generating each service-wise report, I want this header to automatically reflect the corresponding service name.
Problem:
The header value is not getting updated dynamically even though the rest of the data is working fine.
Requirement:
For each generated report (per service), the header “Service Name” should show the correct service (e.g., Assess, Repair, Install, etc.)
The format/layout of the Excel sheet should remain unchanged
Question:
What is the best approach to dynamically populate a header field like “Service Name” from another data source while generating formatted Excel reports
In AutomationEdge Process Studio, you can dynamically update a header cell (e.g., B1) while populating a separate data table and preserving the Excel template layout. The following approaches can be used depending on your workflow design.
Approach 1: Two Microsoft Excel Writer Steps (Recommended)
Step 1 – Write the header
  • Use a Microsoft Excel Writer step with the template file.
  • Set Start writing at cell to B1.
  • Enable Omit Header and Leave styles of existing cells unchanged.
  • Include only the Service Name field.
Step 2 – Write the tabular data
  • Add a second Microsoft Excel Writer step targeting the same output file and sheet.
  • Configure the file and sheet options to Write to existing.
  • Set Start writing at cell to A5 (or your table’s starting cell).
  • Map the required data fields and preserve existing cell styles.
Approach 2: Parent–Child Workflow
This approach is useful when generating separate Excel reports for different services.
  • Parent workflow: Group or filter records by Service Name and use a Workflow Executor configured to execute for every input row.
  • Pass the service name as a parameter to the child workflow.
  • Child workflow: Retrieve the parameter using Get Variables and use it to generate the output file name.
  • Use the two-writer strategy from Approach 1 to write the service name to B1 and the corresponding dataset from A3.
