The workflow works fine in the laptop while running it, but once I published it on to the AE server it has been throwing this exception. Not sure what is causing this cause when I checked again on the Process studio the connection was fine and it worked fine.
The DB connection is a local MySql setup in the laptop.
Any idea on what is causing this issue? cause this has been working fine in the process studio. Only facing this issue once it was published on to the server.
