How to connect Database in Automation Edge i am getting an error while connecting the database
Hi Yogita,
Which DB are you trying to connect to? Also from where? Process Studio or AEUI? Also share the error that you are getting please.
Hello Sir @hemanshu.rukadikar I am trying to use MS Sql server Native using Insert/Update Plugin. Here is the below screenshort
What is the error you are getting?
