How to Connect Database in Automation Edge i am getting an error while connecting the database
Hi Namrata,
There is table input, table output, and other plugins, select one as per your requirement, and when you open the plugin configuration you will see the options required for connection of DB table. just select general and your connection type for example: postgres sql, my sql etc.
Based on the type of connection you can see the related parameters required on the right side.
