Unable to install process studio in windows 10 OS
Hi Team ,
I am unable to install process studio , and when i am running process-studio.bat file facing below error .
HI murali,
Welcome to the community. Just FYI, AE Process Studio support Java 11 and not 16. That being said, in your case, it is using bundled Java so version should not be an issue. Can you please share your process-studio.log file from process-studio>logs directory if the file has been created?
Hi Murali,
Kindly remove the space from the process-studio installation directory and check.
In your case, the “Automation Edge” folder contains space.
Hi Hemanshu,
Log file is not generated .
Hi Rakesh ,
After removing space AE studio is opened ,but after giving credentials getting connection failed exception
Log :
2021/07/02 09:38:34 - AutomationEdge Process Studio - Using JAVA version: 11.0.9
2021/07/02 09:38:34 - AutomationEdge Process Studio - Using JAVA from path: F:\AutomationEdge\process-studio\java
2021-07-02 09:38:34 main INFO ProcessStudioProperties:40 - Succeessfully Initialized the ProcessStudioProperties using process-studio.properties
2021-07-02 09:38:44 main INFO HostDetailsUtils:106 - Mac addresses are : [E4:D5:3D:25:A3:65]
2021-07-02 09:38:49 main ERROR ProcessStudio:12018 - Error while authenticating/registering Process Studio {}
org.apache.http.conn.HttpHostConnectException: Connect to localhost:8080 [localhost/127.0.0.1, localhost/0:0:0:0:0:0:0:1] failed: Connection refused: connect
at org.apache.http.impl.conn.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:159) ~[httpclient-4.5.3.jar:4.5.3]
at org.apache.http.impl.conn.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:359) ~[httpclient-4.5.3.jar:4.5.3]
at org.apache.http.impl.execchain.MainClientExec.establishRoute(MainClientExec.java:381) ~[httpclient-4.5.3.jar:4.5.3]
at org.apache.http.impl.execchain.MainClientExec.execute(MainClientExec.java:237) ~[httpclient-4.5.3.jar:4.5.3]
at org.apache.http.impl.execchain.ProtocolExec.execute(ProtocolExec.java:185) ~[httpclient-4.5.3.jar:4.5.3]
at org.apache.http.impl.execchain.RetryExec.execute(RetryExec.java:89) ~[httpclient-4.5.3.jar:4.5.3]
at org.apache.http.impl.execchain.RedirectExec.execute(RedirectExec.java:111) ~[httpclient-4.5.3.jar:4.5.3]
at org.apache.http.impl.client.InternalHttpClient.doExecute(InternalHttpClient.java:185) ~[httpclient-4.5.3.jar:4.5.3]
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:83) ~[httpclient-4.5.3.jar:4.5.3]
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:108) ~[httpclient-4.5.3.jar:4.5.3]
at com.automationedge.ps.ui.studio.ProcessStudio.nativeAuthentication(ProcessStudio.java:12115) ~[process-studio-ui-6.1.0.jar:?]
at com.automationedge.ps.ui.studio.ProcessStudio.authenticateOrRegisterProcessStudio(ProcessStudio.java:12012) [process-studio-ui-6.1.0.jar:?]
at com.automationedge.ps.ui.studio.ProcessStudio.showAEAuthenticationDialog(ProcessStudio.java:12259) [process-studio-ui-6.1.0.jar:?]
at com.automationedge.ps.ui.studio.ProcessStudio.registerProcessStudio(ProcessStudio.java:12238) [process-studio-ui-6.1.0.jar:?]
at com.automationedge.ps.ui.studio.ProcessStudio.init(ProcessStudio.java:1123) [process-studio-ui-6.1.0.jar:?]
at com.automationedge.ps.ui.studio.ProcessStudio.createContents(ProcessStudio.java:11097) [process-studio-ui-6.1.0.jar:?]
at org.eclipse.jface.window.Window.create(Window.java:426) [jface-3.3.0-I20070606-0010.jar:?]
at org.eclipse.jface.window.Window.open(Window.java:785) [jface-3.3.0-I20070606-0010.jar:?]
at com.automationedge.ps.ui.studio.ProcessStudio.start(ProcessStudio.java:11127) [process-studio-ui-6.1.0.jar:?]
at com.automationedge.ps.ui.studio.ProcessStudio.main(ProcessStudio.java:928) [process-studio-ui-6.1.0.jar:?]
Caused by: java.net.ConnectException: Connection refused: connect
at java.net.PlainSocketImpl.waitForConnect(Native Method) ~[?:?]
at java.net.PlainSocketImpl.socketConnect(Unknown Source) ~[?:?]
at java.net.AbstractPlainSocketImpl.doConnect(Unknown Source) ~[?:?]
at java.net.AbstractPlainSocketImpl.connectToAddress(Unknown Source) ~[?:?]
at java.net.AbstractPlainSocketImpl.connect(Unknown Source) ~[?:?]
at java.net.SocksSocketImpl.connect(Unknown Source) ~[?:?]
at java.net.Socket.connect(Unknown Source) ~[?:?]
at org.apache.http.conn.socket.PlainConnectionSocketFactory.connectSocket(PlainConnectionSocketFactory.java:75) ~[httpclient-4.5.3.jar:4.5.3]
at org.apache.http.impl.conn.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:142) ~[httpclient-4.5.3.jar:4.5.3]
… 19 more
AEBUG
Hi Murali,
Are you using the T3 cloud instance of AutomationEdge or you have an On-prem setup?
If you are using T3, then your AE URL on the process-studio connection parameter should be https://t3.automationedge.com and not http://localhost.com
Hi Rakesh ,
I am using T3 cloud , I have update to cloud URL and AE Studio is open and asking workspace , could to tell me which workspace we need to give ,
Capture
Hi Murali,
You can create/select your own workspace by clicking on the Browse button.
Thanks Rakesh , Working fine .
