Problem:
“How to upgrade the Plugin jar”
“Updating latest jar for the Plugin on the server”
Solution:
For On-premises:
- Go to the AutomationEdge Portal.
- Login to the System Administrator(Sysadmin).
- Go to Plugins section.
- Search for the specific plugin which you want to upgrade(ex: Web-GUI, DesktopPlugins,etc)
- Click on the Edit button for that specific plugin.
- Select the latest jar file and click on update.
After this, the Agent Status changes to “Updating”. Once Agent Status changes to “Running”.
- Go to the ‘psplugins’ folder and check for that specific plugin folder, the updated jar should present in that folder.
- If it contains old jar also check the name and delete the old one.
Finally, Open the Process Studio
- Go to the Tools section.
- Choose option Sync Plugins.
Now, you are able to use your upgraded plugin.
Regards,
Bhagyashri
AutomationEdge Support
Robotic Process Automation (RPA) || IT Service Desk Automation
